Date/Time: Sat, 18 Jan 2025 01:45:23 +0000
Add additonal symbol - can't change default colour
View Count: 825
[2018-01-20 11:39:26] |
User902464 - Posts: 9 |
Hi, I have been using the new study "add additional symbol" set to display as a line on the close. When I try to change the colour of last (or any subgraph) it just reverts back to the default green when I hit apply. I have version 1684. Thanks |
[2018-01-20 18:38:14] |
Refer to: Color Settings for Graph Draw Types We also have updated the Add Additional Symbol documentation to explain this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-20 23:49:40] |
I know how you are supposed to change the colours but when I try it just reverts back to the default every time. I cannot change "last(SG4)" (for example) from green. If I select another colour and press ok and ok again, the line on close graph will still be green. If I change the colour and press apply, it just changes the colout back to green instantly. I have never had this problem with any other study. |
[2018-01-21 03:51:29] |
From documentation: If Use Chart Graphics Settings for Subgraph Colors is enabled on the Subgraphs tab, then the Subgraph color and width settings on the Subgraphs tab of the Study Settings window do not apply and the color settings are instead set through Chart >> Graphics Settings or Global Settings >> Graphics Settings.
