Date/Time: Sat, 18 Jan 2025 02:01:16 +0000
Time and Sales Window
View Count: 738
[2018-01-19 19:34:18]
Crtfyd - Posts: 281
Is there a way to include "Time and Sales" Window in a Simple Alert?
I see there are Time and Sales Studies, but none have the same parameters as the T&S Window.
For instance: I want to combine Time and Price like in the window, but don't see a study I could use.
I thought if I could reference a line in the window?
2) Also, I read somewhere in support about recording the time and sales for a REPLAY. (Since it only saves 60,000 records, this is way less than my trading hours to 11:00 (2.5 hours). Even those 60,000 I cant seem to get to REPLAY. But what I really need is the replay of the OPEN T&S.
How can I achieve this?
PS I did see that one of your things you're working on is Archived T&S, but until then...?
PSS Also I disconnect to keep the T&S records that I have from the OPEN, but when I change a setting on the T&S Window, I LOSE some of records! I thought maybe if I used a parameter like >300 ASKs or something like that, it was simply condensing, but after returning to the previous settings, the records are gone. I never reconnected the charts, so there shouldn't be any MORE records to push the over 60,000 older records out. So why is it erasing my records even after disconnecting? Does it have something to do with a setting I saw once about purging/flushing some data automatically by Sierra. Either way, I shouldn't lose the records I have after disconnecting...right?
Thx
Date Time Of Last Edit: 2018-01-19 19:43:46
