Date/Time: Sun, 24 Nov 2024 03:41:15 +0000
How to enter with a stop order when using automated trading?
View Count: 1423
[2013-09-23 08:42:09] |
User96231 - Posts: 1 |
I believe placing a stop order on the trading service and let the order get filled when price reaches the pre-set price is faster than having SC send a market order to the trading service after the pre-set price is touched. For example I want to place a long stop order one tick above previous bar's high when certain rules are met, how do I do this? Thanks! |
[2013-09-23 13:09:32] |
Sawtooth - Posts: 4118 |
For a buy entry: -set J71 to 'S' -with a formula, set the price level in J22 -the formula in K3 is the trigger. |
[2013-09-23 17:25:19] |
You can you stop orders in a Spreadsheet. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#BuyEntryLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
