Date/Time: Sat, 18 Jan 2025 01:47:34 +0000
ACSIL hide parameter content
View Count: 754
[2018-01-18 18:27:10] |
Cavalry3162 - Posts: 523 |
Hello SC, is there an (ACSIL-)way to not show (hide) the content of a parameter (see screenshot)? thanks, Andreas |
2018-01-18_13-25-15.jpg / V - Attached On 2018-01-18 18:26:24 UTC - Size: 257.58 KB - 276 views |
[2018-01-18 18:33:07] |
Yes. Use: sc.DisplayStudyInputValues= 0;
Make sure you place this below the sc.SetDefaults code block. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
