Date/Time: Sat, 18 Jan 2025 02:03:16 +0000
Data feed
View Count: 607
[2018-01-18 16:37:44] |
User859795 - Posts: 51 |
Hello, Regarding to my disappointment with CTS T4 data feed, i would like to switch Sierra Chart's main datafeed. What is the difference between "for professionals" and "non-professionals" data feed? Thank you, Zolie |
[2018-01-18 18:21:13] |
If an exchange considered you a professional, it means they want more money from you. This is all. Hopefully you are not considered a professional. You will be treated the same way that CTS considers you currently. There will not be any change. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
