Date/Time: Sat, 18 Jan 2025 01:47:37 +0000
Trying to set Alert for crosses of Yesterdays hi and yesterdays low.
View Count: 604
[2018-01-18 00:54:32]
Robert D - Posts: 24
Getting a syntax error trying to set an alert on the Daily OHLC study for yesterday hi and yesterday low. I have used various versions with no luck. Current version is:
OR( CROSSFROMBELOW(H, SG2), CROSSFROMABOVE(L, SG2)).
OR( CROSSFROMBELOW(H, SG3), CROSSFROMABOVE(L, SG3)).
The SG2 is Yesterdays high and SG3 is yesterdays low. I have also used the CROSSOVER, CLOSE and various other configurations.Get Formula error-SYNTAX! Help.
Thank You,
Bob
[2018-01-18 02:05:16]
Do you have a . entered at the end of those formulas? Remove that.
