Date/Time: Sat, 18 Jan 2025 02:03:03 +0000
Replay Chart Control Panel not at a visible multi screen location
View Count: 1038
[2018-01-16 10:41:12] |
User553714 - Posts: 184 |
Hi, When I click >> Chart >> Chart Replay (Control Panel) the usual Replay Control Panel is not appearing? My suspicion is that SC settings might still be sending this window to monitors 5 or 6 which I have recently moved to another system and which are no longer available on this current development system, (I had the same issue on one of my console programmes which was sending the console to non visible screen coordinates which I could fix myself by changing the code.) I have tried closing the old chartbook and opening a new one, but the replay control panel still does not appear? How can I reset the Replay Control Panel window location to be on the main display? Thanks |
[2018-01-16 10:58:25] |
My apologies, "reset Windows" worked to send everything to the main display again. Regards
