Date/Time: Sat, 18 Jan 2025 08:04:26 +0000
How can I put the UK '£' sign in text?
View Count: 1606
[2018-01-12 23:11:23]
User186889 - Posts: 53
Hello Sierra
I have tried for some time to find a way to put the UK pound symbol '£' into the text box as it always puts a 'J' in the box. I have looked through the support board and help files but the search function seems to have been sharply limited since you've done menu updates. How do I do this please?
[2018-01-16 20:07:02]
User37014 - Posts: 8
Type ALT-156 or ALT-0163 - both produce the £ symbol...
[2018-02-02 15:11:31]
Hello Sierra - Did NOT work
In WORD or NOTEPAD or on this screen, using Alt156 produces the '£' but in the Sierra Text Box - It produces a 'J' in either American or English Keyboard but it does NOT produce '£'
Using ALT163 produces ú or a little 'b' with a dash on the top - again - it also does NOT produce the '£' symbol. I've tried a number of variations inc caps lock and off andf English / American keyboard - also see codes at https://www.alt-codes.net/ - But '£' still will produce - I can't even copy and paste it from another file (example notepad) - It always produces 'J'
Please advise further
Thanks - Mark
[2018-02-02 17:27:20]
The prior answer is not from Sierra Chart support. What you are trying to do most likely is not currently supported since Sierra Chart only supports 8-bit characters at this time.
Date Time Of Last Edit: 2018-02-02 17:27:32
[2018-02-03 12:30:08]
Marmany - Posts: 307
For info my keyboard is configured for UK English. Shift 3 produces £ sign in a Sierra text box
[2018-02-04 14:44:20]
Thanks - But that still produces 'J' regardless if English or US Keyboard and does the same on 2 different Laptops - Very Bizarre
