Date/Time: Sat, 18 Jan 2025 02:06:31 +0000
Sub-Region Top-Cropping
View Count: 808
[2018-01-12 20:23:12] |
User138418 - Posts: 16 |
All Subregions lose indicators which reach the top of the region. I cannot find what I have mistakenly set to cause this. Thanks in advance for help! http://www.sierrachart.com/image.php?Image=1515788277727.png |
[2018-01-12 20:25:33] |
Use this command: Chart Menu: Reset Scales (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
