Date/Time: Sat, 18 Jan 2025 01:57:27 +0000
Referencing Previously Triggered Alerts
View Count: 846
[2018-01-12 17:31:01] |
User439067 - Posts: 48 |
Is there a way to know if a certain bar's alert has been triggered besides duplicating the whole AND statement with [-1] on it? I would like to prevent the alert on the current bar from being triggered if the previous bar had already been triggered. Thanks |
[2018-01-12 19:29:28] |
For something advanced like this you really need to use ACSIL: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-12 19:29:34
[2018-01-12 19:44:44] |
I appreciate your answer, I've been studying your examples but haven't got around to getting my hands around it yet. Thanks. Two more questions, if you'd rather I open a new thread I can: 1. Can you place the closing price of the previous bar minus a certain amount in ticks or dollars using studies? I see the "text display for study" but I can't figure out how to manipulate the values available for display. How would you go about tackling this using just plain studies if possible? This is just a nice to have, not critical. 2. Is there a way to hide the little moving price ticker on the scale of the chart? I use the chart values tool quite often and it sometimes makes it difficult to manage my orders with that thing in the way. I love this software - thank you. |
[2018-01-12 21:59:52] |
1. Have a look at using the arithmetic studies for this: http://www.sierrachart.com/index.php?page=doc/ArithmeticStudies.php 2. No, not at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-12 22:46:12] |
Works perfectly, thanks again.
