Date/Time: Sat, 18 Jan 2025 01:51:58 +0000
With Interactive Brokers, how to specify ARCA and ISLAND for direct access stock trading?
View Count: 1945
[2018-01-12 13:47:16] |
WilliamA - Posts: 26 |
With Interactive Brokers I've been using for example CISCO-STK-SMART as the required code for symbols but the execution is slower than direct access trading with ARCA and ISLAND for example. In IB's Trader Work Station I learned I can specify direct access for any symbol in to trade with direct access. Can you tell me how to code the symbols for ARCA and ISLAND direct access trading in SC for trading on IB please?
[2018-01-12 19:17:48] |
You can just change the exchange part of the symbol to ARCA or ISLAND. Use that as the Trade and Current Quote Symbol: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
