Date/Time: Sat, 18 Jan 2025 01:47:16 +0000
Error in Log
View Count: 627
[2018-01-12 13:00:46] |
User883949 - Posts: 6 |
Any idea of the cause? v1684, happening in several chartbooks without an apparent cause.
[2018-01-12 19:14:36] |
In the folder that Sierra Chart is installed to do you see the SierraChartStudies.dll file? Follow the instructions here to update Sierra Chart to the latest prerelease to make sure that file is installed: Software Download: Fast Update Whatever the cause is, the update hopefully should resolve it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
