Date/Time: Sat, 18 Jan 2025 02:05:14 +0000
Evaluating conditions in the indicator
View Count: 778
[2018-01-11 21:43:21] |
User68117 - Posts: 65 |
Hello, how do I compare some candles in the ASK / BID Difference (Delta), mathematically evaluate the conditions, and display the result in the chart like an arrow over a given candle that meets the rule? Where in SierraChart is it going to do it? |
[2018-01-12 04:25:33] |
You could use the Color Bar Based on Alert Condition study for this: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-12 04:25:44
