Date/Time: Sun, 24 Nov 2024 12:28:17 +0000
volume by price value labels
View Count: 2710
[2013-04-05 04:00:45] |
User57210 - Posts: 121 |
My volume by price study is not showing value labels. I'd like to have value labels for point of control, as well as peaks and valleys. I have the "value label" "show" box checked, values scale for horiz align, and centered for vertical. (I've tried other settings to get them to show up too). The color is not the same as any other color, so it's not "blending in". I can see the vpoc on the profile, and I can also see the extended peak/valley lines on the chart. It's just not showing the value lables. Thanks in advance! |
[2013-04-05 04:02:15] |
http://screencast.com/t/ugXqiihf
[2013-04-05 06:33:23] |
FGBL07 - Posts: 19 |
Here are my settings. I display PoC and Value Area Values (High and Low). Hard to see in the screen shot because they overlap right now. What version do you use? I use 954.
SNAG- 05.04.2013 08.30.46.png / V - Attached On 2013-04-05 06:33:08 UTC - Size: 86.19 KB - 594 views |
[2013-04-05 13:33:12] |
Version 959, I have the same boxes checked as you as you can see in my screenshot posted before...
[2013-04-05 13:35:19] |
No, I have not checked the name label. But maybe the difference is due to the different versions.
[2013-04-06 20:52:06] |
Here is the documentation to enable labels for the Point of Control and Value Area lines: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#POCAndValueAreaExtensionLineLabels Labels on Peak and Valley lines is not currently supported. Please let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-12 14:38:34] |
Rino - Posts: 124 |
Wanted to label Peak and Valley lines. I see this is not supported from Sierra at this time. I would like to cast my vote for this function please. Thanks as always PS I know I could just overlay horizontal lines. However would be great to have like you can with VPOC and Value area labels. |
[2013-11-07 15:59:48] |
User40526 - Posts: 166 |
I would like to see this supported, as well. Values for peaks and valleys. Thanks
[2013-11-08 17:21:58] |
Labels for Peak and Valley lines as well as extending them until future intersection is currently under development.
