Date/Time: Fri, 17 Jan 2025 23:24:06 +0000
sc.BuyEntry
View Count: 987
[2018-01-10 18:56:17] |
User921987 - Posts: 238 |
Will the sc.BuyEntry() function wait an acknowledge message from the exchange before it returns or how I can check that my working limit buy order is fully received and sitting in the exchange ?
[2018-01-10 21:09:38] |
Not at all. It is going to immediately return. You need to check the status of the order by getting the details of the order. Refer to: Automated Trading From an Advanced Custom Study: Getting Order Information Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-10 21:21:01] |
Here is the structure member for order status: Automated Trading From an Advanced Custom Study: [Type: integer] OrderStatusCode And be sure to read the prior response. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
