Date/Time: Fri, 17 Jan 2025 23:43:14 +0000
ATR or supertrend type stop used in twconfig
View Count: 1853
[2018-01-10 17:29:10] |
aknsyu71@gmail - Posts: 54 |
Hi, I would like to use a ATR or supertrend type indicator as a trailing stop but not thru a spreadsheet study. Rather as a OCO attached stop order using the trade window. Is it possible to have a custom order type created for this? A twconfig file? Many thanks |
[2018-01-10 18:12:15] |
The best way to do this is to use this particular study documented here: Attached Orders: Study Controlled Targets and Stops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-10 18:12:21
