Date/Time: Sat, 26 Apr 2025 09:40:34 +0000
Disappearing study: ID:11 subgraph 1
View Count: 865
[2018-01-10 14:35:01] |
User189817 - Posts: 5 |
I have the quoted subgraph on all my charts. It's an integral part of all my trading. For some reason it disappears constantly from my charts. I've tried all kinds of configurations with it to no avail. I always hit apply and OK on both dialogue boxes and then save the chartbook immediately, but it never helps. It's to the point where I'm adding it to the charts I work on (Day, 240, 60, 30) up to ten times a day - for each of the six to seven pairs I focus on. If there's a chart I pull up to work on during the day I have to add it there too. As near as I can tell it happens when I do something to the chart. So if I expand the chart, draw something on the chart, whatever, that seems to trigger the behavior. It's driving my loopy and any help would be much appreciated. I did do a search on the board for the study and subgraph but didn't see anything so if it's there I apologize in advance. |
[2018-01-10 22:10:23] |
You are referring to a study which is from Green Chart. That is not something we provide support four. You need to contact the Green Chart reseller.
