Date/Time: Fri, 17 Jan 2025 23:37:54 +0000
Data Feed problems, or visualisation mistake? // IB - Sierra - FDax - Eurex
View Count: 1104
[2018-01-10 13:37:26] |
User872901 - Posts: 1 |
Hi there, I am using Sierra Chart and I like it a lot. My broker is Interactive brokers. I have the Eurex data feed from them directly. I noticed that in a 5 minute volume bar chart of the Dax Future Contract March 2018, I get different total volume displayed per bar in IB than in is shown in Sierra for the same bar!? Can anyone help? Thanks alot. S |
[2018-01-10 19:04:40] |
Refer to help topic 43: Http://www.sierrachart.com/index.php?page=doc/helpdetails43.html In particular the section about incomplete data from the data feed. You will need to use the Sierra Chart Exchange Data Feed for accurate data as mentioned. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-10 19:06:21
