Date/Time: Fri, 17 Jan 2025 23:32:49 +0000
sierra keeps disconnectin
View Count: 802
[2018-01-10 13:21:28]
User30743 - Posts: 365
co idea why my sierra keeps disconeecting. i have it opened on 3 systems (which should be ok as i have paid one extra) and it keeps disconectng all the time.
can you tell me what is wrong?
it started to happen yesterda at about 15:00 chicago time
attachmentdisckonekted.txt - Attached On 2018-01-10 13:21:21 UTC - Size: 4.45 KB - 471 views
[2018-01-11 00:42:20]
You are using an external service named Rithmic. Disconnections from Rithmic are not something that Sierra Chart can help with.
It might be best to maintain one Rithmic connection and use the DTC server for other instances of Sierra Chart:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
