Date/Time: Fri, 17 Jan 2025 23:31:52 +0000
Daily OHLC Study
View Count: 1460
[2018-01-10 11:14:14] |
User371906 - Posts: 141 |
Hello, I am using study Daily OHLC on my 60 minute chart showing the Daily candle OHLC and it works fine. When I also put on the same chart study Daily OHLC but trying to show the 4hr chart OHLC, the lines are placed on the chart but there not correct? How can I have the 4hr OHLC on the chart showing correctly the lines? I used the global cursor plus OHLC of 4hr chart to verify the lines were not placed correctly so it has to be something not working correctly. Picture attached of charts plus setting for the Daily OHLC study for 4hr lines. Thank you Regards g |
Daily OHLC.JPG / V - Attached On 2018-01-10 11:13:50 UTC - Size: 289.34 KB - 431 views |
[2018-01-10 21:55:35] |
You need to use this study: Previous/Period OHLC-Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
