Date/Time: Fri, 17 Jan 2025 23:38:15 +0000
FDXM fills on DD chart
View Count: 788
[2018-01-10 07:25:51] |
User884550 - Posts: 149 |
is it possible to trade mini dax off the dax chart, or is it possible to display mini dax fills on dax chart? my indicators run on dax, but I trade mini, and this makes it all complicated for trading and journaling |
[2018-01-10 19:51:24] |
Yes. Refer to this setting: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-10 19:52:03
[2018-01-10 20:07:00] |
you made my day, thank you
