Date/Time: Fri, 17 Jan 2025 23:29:19 +0000
Transfer Spreadsheet to another SC instance
View Count: 826
[2018-01-10 06:27:35]
User841591 - Posts: 42
I have 2 SC instance SC1 and SC2 running in different folders. I created a chartbook and spreadsheet in SC1 and want to transfer to SC2. I simply copy the A.cht and A.scss files from SC1 data to SC2 data. When I open the A.cht in SC2, the spreadsheet display as default sheet only and all formula are gone. Any suggestion to help on it.
[2018-01-10 19:18:55]
We cannot comment on this because we cannot know exactly what you have done. You should not have trouble with this as you describe.
What we recommend you do is to follow the instructions here for a reliable method to accomplish this:
Sharing Your Spreadsheet Study With Another User
Date Time Of Last Edit: 2018-01-10 19:19:15
