Date/Time: Fri, 17 Jan 2025 23:27:18 +0000
[User Discussion] - Jan 2 Signals shifted to spreadsheet Line 4
View Count: 896
[2018-01-10 00:53:31]
User791263 - Posts: 151
I have SC and AMP accounts. Usually I have to put $$ on the SC account to get help.
Let me know if you need that. My question last summer regarding spreadsheets being reformatted by version change was not really answered- it was complex to explain--
so I am stuck on V1481 and cannot upgrade.
Title of Post should say Jan 5, shifted.
The current problem: Signals shifted to Line4 on Sheet from Line 3, so no Orders issue on Activity Reports.
This is different than Auto Trading Not working
The Chart signal Arrow and K-column just pop into Line K4 & prior Chart bar (1-second charts) at beginning of bar- seems to flicker in as bar/line 3 changes. What previously occurred in Line 3 happens between bars, so SC doesn't see it as a true Spreadsheet Line 3 signal. This started happening just after I restarted SC, Jan 5.
The Trade Activity window and Orders Window stopped all Output Jan 5 after restarting SC.
This had all worked fine. I often look at settings.. so a slight possibility exits that I accidentally bumped some setting.
I did re-order and change the source studies for two Moving averages and added one on a 1-second chart which might have reached it's limit (79 studies) for interconnected charts priority timing.
I reread your documentation. I made no changes to autotrade spreadsheet settings. Setting: Signal once per bar, but not strict.
Enhanced Logging does not work since Line 3 no longer gets the "True".
A few days earlier I did some J27 Work to cancel unfilled orders after X bars or X time; J27 worked OK in late Dec. 2017.
I read an SC post about J27 (Cancel Working orders formula) cancelling the current K3 BUY, but mine had worked OK before (formula: X bars Or X time since last Order). I forced that to =0; still no orders.
Maybe the size of my system surpassed SC's capability in arrays, tables-- it's rarely hit 16 Gig (total memory) with 4 days of data and reconnecting to feed (56 charts, 12 spreadsheets of few hours data). Usually it runs about 2.3 Gig.
Date Time Of Last Edit: 2018-01-10 15:53:41
[2018-01-11 02:36:16]
Hold up on this. I apparently fixed it by restoring from Jan 4 backup and adding in my changes.
Whatever happened on Jan 5, I don't know. Maybe the odd sequence of changes.
Maybe you have some ideas from what you have seen others do, to caution us.
Have you ever seen that jumping to Line 4 of signals exactly on the bar change? Seems like a timing issue. maybe a time since order suppression error (J27).
