Date/Time: Fri, 17 Jan 2025 23:25:05 +0000
Symbol display study
View Count: 667
[2018-01-09 22:47:17] |
User32722 - Posts: 10 |
After last update symbol display study print over price. Draw study underneath price is checked....
Screen Shot 2018-01-09 at 23.46.11.png / V - Attached On 2018-01-09 22:46:36 UTC - Size: 18.99 KB - 284 views Attachment Deleted. |
[2018-01-10 03:35:17] |
This will be corrected in the next release which we are putting out later this evening. Also there is a new Study Input which controls this but it is working in reverse and that is what we are correcting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
