Date/Time: Fri, 17 Jan 2025 23:42:42 +0000
[User Discussion] - Subgraph for extended rectangle with terminate at intersection?
View Count: 1177
[2018-01-09 22:05:07] |
samual sprat - Posts: 343 |
Hi, Is there a subgraph that can plot an extended rectangle out to the right and terminate when it has an intersection with a future bar? Doubt it's possible now, but would be great if you had the option to define which bar and also the open/high/low/close of the bar to base the high and low of the extended rectangle on Something like this: https://apazones.com/wp-content/uploads/2014/11/EURJPY-Daily-1-2014-11-14-17_46_01.372.png Thanks, S |
