Date/Time: Fri, 17 Jan 2025 23:28:26 +0000
Variables in Spreadsheet Columns moving from one column to the other if something added
View Count: 697
[2018-01-09 11:03:41] |
User252419 - Posts: 235 |
If I add some drawing or study into the chart with the current spreadsheet, some variables change its column. Is there any way to fix these columns so I don't need to change Cells in Formulas each time I make some change in the chart? Thank you |
[2018-01-09 12:32:42] |
You need to change the method by which the Study Subgraph columns in the Sheet are being referenced. Refer to: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
