Date/Time: Fri, 17 Jan 2025 23:33:43 +0000
About NewOrder.OrderQuantity and the qty in Trade Window
View Count: 703
[2018-01-09 06:59:03] |
User841591 - Posts: 42 |
When I design a ACSIL trading system, I specific the sc.TradeWindowConfigFileName="2T_CommS.twconfig" in the sc.setDefaults. I'd like to ask if I do not set NewOrder.OrderQuantity in ACSIL, will it follow the Qty value in the Trade window of "2T_CommS.twconfig". Moreover, if the Qty value in NewOrder.OrderQuantity and trade window is different. Which one will be followed? |
[2018-01-09 10:25:15] |
You do need to set the the order quantity. NewOrder.OrderQuantity will be followed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
