Date/Time: Fri, 17 Jan 2025 23:27:23 +0000
multiple AOS studies in one chart
View Count: 983
[2018-01-08 22:36:01]
User30743 - Posts: 365
hi, i would like to ask about how to make multiple ACSIL autotrade studies work in one chart.
lets say i want to trade on YM and and i have 5 different DLL studies each with a different condition for entry into market, all are set only for LONG direction
can i put all the studies in one chart or should i use each DLL in a separate chart?
the issue i am trying to understand is this: i put all the DLL files into one chart, and lets say DLL number1 will have a signal to open a trade, and while still being in the position, another signal for DLL number2 appears - will DLL number2 open the position?
from what i have seen, it will not. even though i have "Allow entries with working orders" - YES
when i put "allow multiple orders in the same direction" - YES what will happen is, that the same DLL number1 which is currently holding a position open another trade on the same signal, which is something i dont want to.
i need to take only the first signal of each DLL and wait till PT or SL. but while holding the position, all other studies are allowed to open a trade, the same study is not.
is it clear from my explanation?
will it work if i use a separated YM chart for each DLL study? or is thera any way how to set it up?
Date Time Of Last Edit: 2018-01-08 22:41:59
[2018-01-09 12:46:52]
Here is the relevant documentation for this:
Automated Trading Management: Using Multiple Automated Trading Systems at the Same Time
Assuming you can make this work properly, it does not matter if they are on the same chart or different charts.
