Date/Time: Fri, 17 Jan 2025 23:38:35 +0000
3 issues from customer, any help would be great
View Count: 1501
[2018-01-08 14:57:53] |
Glenn Infinity - Posts: 103 |
discuss 3 issues with sierra?1. how do you get the tpo value lines indicatior from squinching up your charts to show all the lines. price is more important and I only want to see the tpo lines when price comes near. instead it squinches your prices to see vah, poc val on one screen and you constantly have to resize. with some 3rd parties like vsa tradeguider you cannot adjust price at all and so u cannot see the charts2. how do you keep current price centered on your chart and not moving off with large price swings3. why did the new update take away unirenko charts. flexrenko is NOT the same!! please use your influence to make them give us unirenko charts back.
[2018-01-08 19:30:42] |
gomifromparis - Posts: 244 |
Concerning the Renko bars, I will be publishing shortly GomUniRenko bars, which uses the monpere's NinjaTrader algorithm in its awesome purity :-) It will included a couple enhancements, specifically for bitcoin/Bitmex , ie possibility to have the Renko tick size varying continuously with price. I include a couple teaser charts :-) |
Attachment Deleted. GomRenkoGapManagement.png / V - Attached On 2018-01-08 19:29:10 UTC - Size: 32.94 KB - 457 views GomRenkoVariableTickSize.png / V - Attached On 2018-01-08 19:29:17 UTC - Size: 27.44 KB - 349 views GomRenkoPriceAlteringSettings.png / V - Attached On 2018-01-08 19:29:25 UTC - Size: 31.33 KB - 368 views GomRenkoNewBarLevel.png / V - Attached On 2018-01-08 19:29:38 UTC - Size: 16.93 KB - 404 views |
[2018-01-08 20:38:54] |
2. how do you keep current price centered on your chart and not moving off with large price swings 3. why did the new update take away unirenko charts. flexrenko is NOT the same!! please use your influence to make them give us unirenko charts back. 1. Refer to the section here for this: http://www.sierrachart.com/index.php?page=doc/Scaling.html#BasingScaleOnlyOnPriceBars 2. Use a Constant Range Scale for the chart. Refer to: http://www.sierrachart.com/index.php?page=doc/Scaling.html 3. This has just been renamed. Refer to: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html#UniversalRenkoBars And make sure you are using the correct Renko New Bar Mode for what you require: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html#RenkoNewBarMode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-08 23:21:01] |
3. For the Renko New Bar Mode this is what you will probably want to use: New Trend Bar When Range Exceeded | New Reversal Bar When Reversal Amount Met Plus 1 Tick and References Prior Close Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
