Date/Time: Fri, 17 Jan 2025 23:25:32 +0000
Turning off Message Log
View Count: 2065
[2018-01-08 14:27:45] |
User41683 - Posts: 37 |
Hi, is there a way to turn off the Message Log. It is posting constantly a message that is of no interest to me. Thanks. |
[2018-01-08 19:37:25] |
What is that message? Copy it with Copy Selection and paste it here. You can also enable this option: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#NeverAutomaticallyOpenMessageLogOrTradeServiceLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-08 20:32:10] |
The error was a Windows error that occurs because of a custom study that works very well but sadly generates that Windows error. Very annoying when it pops up regularly.
[2018-01-08 21:01:41] |
OK contact the developer of the study about this. This should never be happening to begin with.
