Date/Time: Fri, 17 Jan 2025 23:36:59 +0000
How to allocate a specific sound to a specific SG within one STUDY ?
View Count: 869
[2018-01-08 13:27:08] |
s291117 - Posts: 28 |
Hello Support, I have check the page dedicated to Alerts: Study/Chart Alerts And Scanning but I did not find what i was looking for (like the US song..) None of the examples clarify how to allocate a specific sound to a specific SG within one single STUDY. If I want to apply 4 specific sound alert for the Daily OHLC study: one for the open, another for the close, one for the high and the last one for the low. SG1, SG2, SG3, SG4 respectively. I have alreay created the 4 sounds. Please see attached screenshot. I just would like you to send the part of code that make the correspondance between one SG to a sound that has been already registered withint the platform. =CROSSOVER(SG1,C), and then the code that say, trigger sound alert n°.. =CROSSOVER(SG2,C), =CROSSOVER(SG3,C), =CROSSOVER(SG4,C) This example could be added on the help as it might improve the personnal use one can make of Sierrachart. Besides, i have another request relatively to the fact that the user loose all the sounds correspondance he has created previously to a full and clean reinstallation of Sierra. There seems to be no profil allowing to save them (Alert 1 = specific sound, Alert 2 = ecc.) Could you has this feature please. Really ? Thanks for your precisions. |
sc_sierrachart_Daily-OHLC_SG.jpg / V - Attached On 2018-01-08 13:23:02 UTC - Size: 539.56 KB - 362 views |
[2018-01-08 19:23:01] |
None of the examples clarify how to allocate a specific sound to a specific SG within one single STUDY. You will need to use ACSIL to accomplish this: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php Or use 4 separate Daily OHLC studies each one set to a different Alert Formula and Alert Sound Number. Besides, i have another request relatively to the fact that the user loose all the sounds correspondance he has created previously to a full and clean reinstallation of Sierra. There seems to be no profil allowing to save them (Alert 1 = specific sound, Alert 2 = ecc.) http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-10 18:59:13] |
Sir, I am not a programmer. Perhaps, one day, you will implement the possibility to add specific sound for each SG. Thx. |
