Date/Time: Fri, 17 Jan 2025 23:41:05 +0000
Problem with Auto-Set from Data Feed box in Chart Settings
View Count: 1339
[2018-01-08 11:19:37] |
User10875 - Posts: 42 |
Hello, I have historical chart on which I frequently change the symbol (manually and via quote sheet). Within in the chart settings the tick size is manually set to 0.01 and " Auto-Set from Data Feed" is unchecked (disabled). Now everytime I change symbols, the "Auto-Set from Data Feed" box is automatically rechecked and the tick size automatically changed to 4 decimal places (0.0001) with the result that the volume profile is not correctly displayed. |
[2018-01-08 16:27:11] |
We see you are using TeleTrader. Give us some examples of the symbols this is happening with, and we will set up Symbol Settings for those.
[2018-01-09 08:58:09] |
Ok, see below some symbols where this is happening, but it is just a small selection as I am working with a variable list of nearly 200 stocks. Changing settings for a large set of symbols might be to much work for you. Would it be possible to prevent the "Auto-Set from Data Feed" box of beeing autmatically checked everytime a symbol is changed? That would be completely sufficient for me. Selection of symbols where this is happening: ZAL.STk.ETR WCH.STK.ETR SAX.STK.ETR AIXA.STK.ETR DBK.STK.ETR RWE.STK.ETR |
[2018-01-09 12:19:44] |
This is no problem. We are going to set up patterns for these. Just allow about 15 minutes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-09 12:19:52
[2018-01-09 13:10:41] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
