Date/Time: Fri, 17 Jan 2025 23:41:06 +0000
switching to IB from FXCM, how to keep/save/store FXCM settings (for later use if needed)?
View Count: 848
[2018-01-08 04:35:40] |
Rainer - Posts: 110 |
What is the simplest way to store/save my current FXCM settings (login, setup, etc.), during the initial switching/testing phases using IB (and without messing up my current FXCM settings)? In other words, how to easily run SC with either the new IB settings or previous FXCM settings, but not using both multiple Trade Services at the same time? ... couldn't find anything specific/conclusive on the SC website. Date Time Of Last Edit: 2018-01-08 05:20:07
[2018-01-08 21:28:07] |
Just install another copy of Sierra Chart. That is the best thing to do. Refer to: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
