Date/Time: Fri, 17 Jan 2025 23:42:27 +0000
When study don't have a OHLC bar(or candle) draw style.
View Count: 1146
[2018-01-07 16:00:36] |
Cyberdogk9 - Posts: 27 |
Hi, is there a way to draw study subgraph like OHLC bar when study only allows OC bar? For example, I use "study sugraph subtract/difference" based on uptick volume minus downtick volume and I want it to look like OHLC bar not just OC bar. The same with "rate of change study". So I need it to draw tails! |
[2018-01-08 02:11:08] |
For this, you need to use this study: Study Overlay - OHLC (Open, High, Low, Close) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-08 02:44:12] |
What Did I Do Wrong?
EURcad [M] Rev. 6t #2 2018-01-07 21_39_08.464.png / V - Attached On 2018-01-08 02:44:02 UTC - Size: 68.55 KB - 374 views |
[2018-01-08 17:19:07] |
up
[2018-01-08 20:52:21] |
It looks like that study is referencing chart #8. What is the timeframe of those chart bars in chart #8? Posted image of that chart by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-08 23:27:42] |
I closed that chart yesterday... I created another one just for screen shot. So charts #3 and #4 are the same thing but chart #4 is one minute timeframe and #3 is 5 minute(tried other combinations). And the result i will upload here. This "study overlay OHLC" doesn't make any sense to me. I tried absolute possible way to make it work, but end up with nothing. |
EURcad [M] 5 Min #3 2018-01-08 18_19_04.161.png / V - Attached On 2018-01-08 23:25:28 UTC - Size: 61.31 KB - 314 views |
