Date/Time: Sun, 24 Nov 2024 04:13:09 +0000
Advanced Custom Study ToolBar Buttons and Mouse Pointer Events
View Count: 1516
[2013-09-20 13:23:20] |
crazybears - Posts: 314 |
Hi I'm trying to developed 2 custom buttons , when i click on one should start my program . i'm seeing that if the chart is detached or i detach it the my program doesn't work or stop to work . am i wrong on something ? or when a chart is detached sc.MenuEventID and sc.MouseEventType aren't recognized? Thanks max |
[2013-09-24 23:58:15] |
The use of ToolBar buttons on detached charts may not be entirely reliable. This is something that is planned to be improved upon. It is a significant development task and it is something we have not yet started.
[2013-09-25 00:45:17] |
M5amhan - Posts: 468 |
i use a separate detached toolbar for my detached charts if that helps any
