Date/Time: Tue, 11 Feb 2025 21:14:01 +0000
[Programming Help] - indicator to measure open to close spread of each bar
View Count: 2117
[2018-01-06 18:02:03] |
User970210 - Posts: 100 |
hi, I am wondering whether there are any indicator to measure open to close spread of each bar? thanks |
[2018-01-07 01:16:28] |
Yes. Use the Bar Difference study: Bar Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-07 11:21:27] |
User786248 - Posts: 25 |
When using bar difference, I would like to display the value of the bar difference below bar's low only when it has exceeded a certain value? Example, show only bar difference > 10 pts and display below bar's low thanks |
[2018-03-07 22:24:04] |
This is possible: http://www.sierrachart.com/image.php?Image=15204613561000.png The attached Study Collection does this. For instructions refer to: Study Collections: Using a Study Collection Provided by Sierra Chart Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-07 22:25:53
[2018-03-08 03:10:12] |
Which study can allow me to draw a horizontal line at 50% between the Close and Open of a bar for a minimum of 5 bars forward? thanks |
[2020-09-24 20:22:31] |
User183495 - Posts: 3 |
Hello. Could you tell me how to display the value of the bar difference (Open -Low) below bar's low and the value of the bar difference (High - Open) above bar's high? |
[2020-09-24 20:31:19] |
John - SC Support - Posts: 37887 |
You just need to use two copies of the Bar Difference study along with two copies of the Study Subgraph Above/Below Bar As Text study. Refer to the information here: Bar Difference and here: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
