Date/Time: Fri, 17 Jan 2025 23:26:13 +0000
GDT_RENKO_WICK in an example
View Count: 985
[2018-01-06 04:04:48] |
LenderDevTest - Posts: 15 |
Old data in the documentation. GDT_RENKO_WICK using in an example, but isn't supporting in current version Sierra ACSIL Interface Members - Variables and Arrays: sc.RenkoTicksPerBar |
[2018-01-06 21:42:44] |
This has been corrected in the documentation.
[2018-01-08 22:33:51] |
There also no AreReversalBars(); ArePointAndFigureBars() in related doc in ACSIL Interface Members - Functions https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html |
[2018-01-09 12:43:56] |
You need to use this new function: sc.GetBarPeriodParameters() This is supported in the latest prerelease. The functions you mention in post #3 are considered out of date at this time and should no longer be used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
