Date/Time: Sat, 18 Jan 2025 05:17:38 +0000
Working with Spreadsheet - volume at price
View Count: 1512
[2018-01-04 09:48:20] |
User215298 - Posts: 20 |
Good morning, hope you are good. I am working with spreadsheet study and I would like to have the amount of volume at the poc price for a specific candle. I can see that the spreadsheet easily gives me the poc price, the candle volume etc. but what I am looking for is the volume (or "horizontal volume" if it can help figuratively) that we have at the poc for a specific candle example: we have a 1h candle, we have a poc at 1.123456. what is the volume at 1.123456? I can see that this can easily displayed on a chart, but canĀ“t figure it out how to have it in a spreadsheet study. Thanks a lot! |
[2018-01-05 00:32:54] |
This is still pending review.
[2018-01-27 23:00:27] |
We have added this ACSIL function: void sc.GetPointOfControlPriceVolumeForBar(int BarIndex, s_VolumeAtPriceV2& VolumeAtPrice); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-27 23:02:56] |
We have read your post again and you require this for a spreadsheet. So what we can do that is using that new function create a new study to get this value. We will do that.
