Date/Time: Fri, 17 Jan 2025 23:20:42 +0000
Charts not loading
View Count: 1746
[2018-01-03 16:38:16]
User90927 - Posts: 38
I have just installed the current version of Sierra Charts on my new PC ( Infinity AT 5.6.9.3)
The starting page appears along with the Trading Dom , but the charts are not loading up.
What can I do ?
[2018-01-03 17:50:31]
It is not clear what the issue is. Is there a problem opening a Chartbook?
Here are the instructions to open a Chartbook:
Chartbooks (Workspaces)
Is there a problem with the historical data in a chart you open?
Or something else?
[2018-01-04 15:26:10]
I cant get to the chartbook page.
The version that has loaded up on my new pc is 5.6.9.3 whereas on my old pc it is showing as 5.6.7.11. On my old pc the charts load up auto. (No Problem)
When i log on the Trading platform page comes on along with the trading dom but the charts do not load up auto. or manually.
I cant get access to the charts page where where file ,edit, chart etc comes up
[2018-01-04 19:02:30]
Does this file exist on your system:
C:\SierraChart\SierraChartTransActMA\SierraChart.exe?
If so, try running it by double-clicking on it and let us know what you see.
Date Time Of Last Edit: 2018-01-04 19:03:06
[2018-01-05 15:31:33]
Where can I find the Sierra Chart file ?
Sorry I am not computer literate
[2018-01-05 15:35:23]
Use the program called Windows Explorer on your computer. And then navigate to this folder within Windows Explorer:
[2018-01-05 15:48:01]
I dont have it...but InfinityAT is loaded down
[2018-01-05 23:00:04]
We need to approach this differently. We want you to install Sierra Chart using this installer:
https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe
After it is installed, it will run. Tell us what you see at that time.
Here are the detailed instructions:
Software Download: Installation and Upgrading Instructions
Date Time Of Last Edit: 2018-01-05 23:01:18
[2018-01-09 15:39:16]
I have tried clicking on the link and installing...but the result is the same.
The chartboard and the trading dom appear but the charts are not loading up automatically or manually.
[2018-01-10 19:20:48]
Do you have this file on your system?:
C:\SierraChart\SierraChart.exe
Date Time Of Last Edit: 2018-01-10 19:20:55
