Date/Time: Mon, 20 Jan 2025 14:02:18 +0000
Market Depth Historical Graph
View Count: 1002
[2018-01-03 16:20:18]
User98657 - Posts: 329
I would appreciate it very much if, when you get time, you could make an adjustment/improvement to the Market Depth Historical Graph.
I use Quantity Numbers on the right side of the graph and so i set In:6 to "yes". But i do not want to see the quantity on the graph at every level. It would be much better to be able to choose to see either, or both.
I want to see the quantities on the right but they create too much noise if scattered across the entire chart.
[2018-01-03 17:52:30]
OK we will see about adding a new Input to control this.
[2018-01-04 14:25:37]
thanks.
[2018-06-26 17:16:35]
I just thought i'd check in and see if this was still a possibility.
[2018-06-26 20:54:58]
We have not yet gotten to this. It is planned.
