Date/Time: Sun, 24 Nov 2024 03:56:02 +0000
Global Line
View Count: 1251
[2013-09-19 18:10:59] |
infpz - Posts: 826 |
Can we draw a line on one chart that shows up on others charts?
[2013-09-19 18:30:12] |
Yes. Refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
