Date/Time: Fri, 17 Jan 2025 20:47:07 +0000
Spreadsheet system for trading study
View Count: 778
[2018-01-03 14:37:40]
User192121 - Posts: 1
my spreadsheet system for trading study has studies from an old chart that show up in the spreadsheet cells. It does not show the studies of the new chart. This is the case with all the sheets withing the study.
It may be that the settings were saved as the default settings and now it isn't populating. How do I get the file where it has the programs original settings and then get the current studies to populate on the spreadsheet so I can begin working with it.
[2018-01-03 17:48:55]
Make sure you are looking at the correct Sheet in the Spreadsheet and that the Chart Data Output Sheet Number Input is set correctly:
Spreadsheet Study Inputs: Chart Data Output Sheet Number
Also refer to:
Working with Spreadsheets: Difference Between Sheets and Spreadsheets
