Date/Time: Sat, 19 Apr 2025 09:42:46 +0000
Menu Text Size
View Count: 1797
[2018-01-03 07:49:14] |
andrew miles - Posts: 21 |
I have been trying to change the text size of the main menu system (File, Edit, chart, analysis etc) I can find everything to change fonts for other items but not the menu. Is it possible? thank you
[2018-01-03 08:45:44] |
This is controlled at the operating system level. Refer to: https://www.wikihow.com/Change-the-Default-Font-on-Windows-7 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-19 02:31:15] |
nelligan - Posts: 6 |
Hello, indeed there's an option for " make text size bigger" in windows but it doesnt affect your inner menu. Just the title above the window see screenshot. At 225% VS 161%, the text in the menu doesnt change at all. What can I do about that as Sierra chart is pretty "menu intensive" and I'd like to have some ease while reading through everything. Thanks in advance Date Time Of Last Edit: 2025-03-19 02:31:48
[2025-03-19 19:06:13] |
Sierra_Chart Engineering - Posts: 19276 |
Looks like you are referring to what are called the Windows dialogs. Changing the menu size does not affect those. Those are being updated to the new settings Windows format gradually: Settings Windows Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
