Date/Time: Sun, 24 Nov 2024 03:46:34 +0000
TPO Profile chart request
View Count: 1411
[2013-09-19 17:43:07] |
User18839 - Posts: 3 |
Hi, Hope you are well. I was wondering if anyone could possibly be of assistance. I am looking to setup a tpo chart on a 30 min periods. What I would like is for the price fluctuations within each 30 min period to be represented via letters as well as the letters to be spaced apart so that the tpo's can be viewed clearly once each 30 min profile is merged together. I have read through the tpo profile chart documentation to gain direction on how to do this, however I am still not achieving the tpo chart I desire. Any assistance would be of great help. |
[2013-09-19 18:32:22] |
So you want to the overall TPO profile to be 30 minutes. What should the timeframe of the individual letters be?
[2013-09-19 19:31:52] |
I would like each column of the overall profile to represent 30 minutes of price movement, and then merge all the 30 minute profiles together to get the overall profile, does that make sense? Thank you and Kind regards |
[2013-09-19 21:18:44] |
Still not completely clear. A "column" in a TPO profile cannot represent a fixed amount of time. It will be variable because it can consist of multiple sub time frames within the overall profile. One thing you can do is create a TPO profile that is 30 minutes overall and each sub time frame can have a duration of one minute. Or you can create a TPO profile which is 1 Day or any other time period and each sub timeframe can be 30 minutes or some other number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-19 21:19:13
