Date/Time: Sat, 18 Jan 2025 05:17:20 +0000
Number of Trades
View Count: 1541
[2018-01-02 22:46:48]
Crtfyd - Posts: 281
I am using a Number of Trades Chart set to 100
For a Simple Alert, how would I reference the bars within one second?
In other words, There are two bars for 9:34:07 (9:34:07.006 & 9:34:07.019).
If I wanted a simple alert to alert me when 2 bars are within the 9:34:07 time frame, what Simple alert would I use since its dealing with a fraction of a second?
[2018-01-03 04:44:34]
We need to spend some time to look into this. Probably we should create some Spreadsheet comparison functions to compare to the nearest millisecond, second, minute and hour.
[2018-01-04 20:50:44]
Crtfyd - Posts: 281
I'm thinking something like: BARTIME[-1] < (L < L[-1]) < BARTIME[1]
to represent 2 bars with the same "seconds" time (ie:2 bars 9:45:06.004 & 9:45:06.102 ) where the Low of the .004 bar is lower than the .102 bar.
But I don't know how to address the BARTIME
[2018-01-04 21:22:58]
Crtfyd - Posts: 281
I tried: =AND ( TIME[-1] < (L<L[-1]) < TIME[1] )
...but it doesn't work either
[2018-01-05 02:23:19]
This is what you will need to use but it is not yet supported:
=ISSAMETIMETOSECOND(BARTIME[-1]), (BARTIME[0])
Allow a few days for this.
[2018-01-10 16:14:03]
Crtfyd - Posts: 281
Is the last response by you supported yet?
Thx
[2018-01-10 17:21:21]
No not yet. Probably not for another week.
[2018-01-10 17:34:09]
Sawtooth - Posts: 4154
This works:
=FLOOR(BARTIME,1/86400)=FLOOR(BARTIME[-1],1/86400)
[2018-01-25 17:19:31]
Crtfyd - Posts: 281
What does "FLOOR" mean?
Thx, but that doesn't seem to do it. I think bc its referencing time, because some bars take longer to develop. For instance, with your suggestion, I get an alert when there is only one bar for the second, but it took a long time to get to the 100 trades, therefore triggering your over 86,400 (milliseconds?) It worked on some, but gave false alerts.
I would image somehow need to reference over 100 trades within one second.
[2018-01-25 17:47:31]
The FLOOR function rounds down to a multiple, in this case, a multiple of one second.
One second in Serial Date Time format is equal to 1/86400 because there are 86400 seconds in 24 hours.
So this formula would strip any millisecond increments from the current and previous bar's time stamps, and alert when they were both the same time to the second.
Set the alert to occur at bar close.
Date Time Of Last Edit: 2018-01-25 17:48:56
[2018-01-25 18:11:34]
Here are the new ISSAMETIMETO* functions:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#ISSAMETIMETOHOUR_Function
Date Time Of Last Edit: 2018-01-25 18:11:51
