Date/Time: Fri, 17 Jan 2025 20:37:52 +0000
Chart Drawing - is there a persistent string or scdatetime property I can use
View Count: 915
[2018-01-02 20:49:13]
User735389 - Posts: 189
Basically I need save the datetime a user drawing was created. This info needs to be persistent. Is this possible? I do not want to use the Text field since I dont want this to be user visible.
[2018-01-02 21:26:17]
Refer to these functions:
sc.GetPersistentInt()
[2018-01-02 21:42:10]
This won't really work with what I'm trying to do. Maybe I wasn't clear with what i'm trying to do.
For each and every user drawing, i need to know the datetime the drawing was created. This needs to be persistent with the drawing even after the program is closed, just like how user drawings are persistent in a chartbook until they are deleted. I need a property that behaves similarly to Text for a chart drawing, except it is not visible by the user. Does that make sense?
[2018-01-02 21:56:37]
OK but this does not exist.
You would need to remember that Date-Time and write it to your own file. Each drawing has a unique LineNumber that you can use to match up these Date-Times to a particular drawing.
