Date/Time: Fri, 17 Jan 2025 20:36:21 +0000
BitMex weekly chart
View Count: 921
[2017-12-31 19:46:15] |
N!co - Posts: 140 |
hi is there a way to set start and end time of a historical chart ? the weekly candle seems to start on sunday and i want the weekly candle to start on monday 00:00:00 UTC Bitcoin starts its new daily/weekly candle at OO:OO:OO UTC time thank you Date Time Of Last Edit: 2018-01-01 06:35:25
12.31.2017-20.42.png / V - Attached On 2017-12-31 19:46:03 UTC - Size: 96.61 KB - 334 views |
[2018-01-03 18:49:26] |
Update to the latest "Prerelease" of Sierra Chart following the instructions here: Software Download: Fast Update And enable this option: General Settings Window: Use Monday as Start of Week instead of Sunday (Global Settings >> General Settings >> General >> Data) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
