Date/Time: Fri, 17 Jan 2025 20:43:30 +0000
Order Fills
View Count: 911
[2017-12-30 17:21:27] |
User909406 - Posts: 4 |
Greetings, Is there a function to be able to aggregate order fills that display on chart? Please see chart snapshot attached. Currently if I receive an execution on 5 contracts many times it displays 5 individual 1 lot fills...I would like it to simply aggregate and display only 1 flag with quantity 5 and price... Is this possible? I have not been able to locate any literature on this subject. Thanks in advance...David |
Order fills.jpg / V - Attached On 2017-12-30 17:19:46 UTC - Size: 12.72 KB - 361 views Attachment Deleted. |
[2017-12-31 22:16:54] |
This is not supported. The closest that is available is using the Trades Tab on the Trade Activity Log: Trade Activity Log: Trades Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
