Date/Time: Fri, 17 Jan 2025 19:51:50 +0000
DOM Optimization
View Count: 1899
[2017-12-29 13:26:24] |
User269566 - Posts: 2 |
Hi, I would like to set up the fastest update interval possible for the trading DOM. I am using only a single chartbook with just a single Dom and no charts. Therefore a fast setting should not slow down my PC. I have noticed that under Global settings>General settings, the Chart Update interval is set to 500 milliseconds by default. Is that setting for charts only or does it apply for the Dom too. If yes, should i set this to <100ms? Many thanks |
[2017-12-29 19:42:10] |
It does apply for Trading DOMs as well. Best thing to do is to use the chart/trading DOM specific Chart Update Interval setting: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) No need to change the global settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
