Date/Time: Fri, 17 Jan 2025 19:48:11 +0000
[User Discussion] - VP Tool
View Count: 831
[2017-12-29 08:32:21] |
nicktrader - Posts: 729 |
Is it possible to add the option "background" to the VP tool. It would be much more easier to see the marking. |
VP Tool.png / V - Attached On 2017-12-29 08:30:07 UTC - Size: 57.39 KB - 301 views |
[2017-12-29 08:47:29] |
Refer to: Notice: Suggestions (Currently not accepting) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
